200 rear tire on a 1999 Nighttrain???
Old 05-31-2012, 09:14 PM
sLaMMEdTrAiN12's Avatar
sLaMMEdTrAiN12
sLaMMEdTrAiN12 is offline
Stage IV
Default 200 rear tire on a 1999 Nighttrain???
Ok, I am new to the forum and have been doing some digging. I have a 1999 Train that already has a 18x5.5 rim with a Metzler 200 tire, but was converted to chain drive. Swingarm and everything else is still stock, just been converted over to chain drive. I want to go back to belt drive, which I have a chance to pick up a 2006 swing arm, but want to run 2007 pulleys and belt, for its the 20mm belt and pulleys geared the same (1 pulley is 1 tooth diff). So my question is, what all do i need to change back to belt drive? Any help is greatly appreciated!
Old 05-31-2012, 09:28 PM
tdpb2008's Avatar
tdpb2008
tdpb2008 is offline
Looks like you will have to pull the primary a part and change the front sprocket to a pulley,rear pulley, an 06 swing arm has a 3/4" axle and uses a 200mm rear stock 06 spacers and I would use pulleys from a 06 so everything will mount up easy
If you decide to move on to a belt let me know what you want to do with the chain and sprockets...I may be interested
Old 06-01-2012, 06:56 AM
sLaMMEdTrAiN12
Stage IV
Will do tdpb2008, Ihopefully someone else will chime in here
Old 06-01-2012, 08:38 AM
tdpb2008's Avatar
tdpb2008
tdpb2008 is offline
yeah alot of good people here that know there stuff and will gladly help with any of your needs
Old 06-01-2012, 08:50 AM
back again's Avatar
back again
back again is offline
Received 4,809 Likes on 2,126 Posts
check your email slammed train.several variables
89incher
12-05-2017 11:37 AM
sgtrod91
06-27-2013 10:11 PM
jm1211
01-05-2010 08:12 PM
mcfaddenfxdx
02-25-2008 04:43 PM
CSTHDSFT
07-12-2007 01:03 PM
Quick Reply: 200 rear tire on a 1999 Nighttrain???
