Relocate turn signals on FXSTC
I would like to relocate my front turn signals on my 07 Custom. I know there are people on the forum who have done it. Can someone tell me if there is a kit available for this? Do I use the same housings with a different mounting bracket? I can handle the wiring, just not sure how to go about this minor improvement. Any help is appreciated. Please post pix. Thanks
RE: Relocate turn signals on FXSTC
There is two ways to do it, you can use the HD relocators like I did.
All you need are the brackets, a couple of stainless steel or chrome washers and acorn nuts and the tools.
Looks like this when your done.
The other type is a pair ofclamps that fitaround the tubes andput the signal itself a little closer in to the tube. Theyclamparound the tube so you can move them up or down where you like.
The ones I have fit under the lower tripple tree pinch bolt. So they are "fixed" in position. But I like having them a bit farther apart so oncoming traffic can see me a little better, I hope.
The washers and acorn nuts are used to put on the bottom of the mirrors where the signals used to be. Looks a bit better than just any old nut you have laying around that fits. Because the threaded part of the mirror is a bit too long for acorn nuts you need the extra washer to take up some room. Sorry the pic is a bit crappy, but the light was a bit dim when I took it.
Have fun [sm=bling.gif]
ORIGINAL: Citoriplus
I can't be absolutly sure but I think theacorn nuts "may" come with the HD relocation kit.
UnfortunatlyI still neededextra washers to get them to tighten upproperly.
I did my own relocation by replacing the bolt at the top of the forks with a stud , bush and screwed the indicator in to it. A little fiddly but worth the effort. It tucks in nicely also.
regards
Mick
[IMG]local://upfiles/21019/8571974BF10342639DA529F8B538226C.jpg[/IMG]
[IMG]local://upfiles/21019/1313A1D3BB9C46EE9FFAC67E8C63AF09.jpg[/IMG]
regards
Mick
Thanks. The new location matches the new headlight nicely.
I will get some pics this weekend and post them. I have been so busy with the mods and work that I have hardly photographed the bike.
As far as the bars go they are the 6" rise Ultima bars with torpedo grips and chrome controls/ levers. They feel prettygood to ride with. My brother is making a set of 8" rise bars pretty much in the same design for his 07 fxstc. THey should be off to the chromers in a week or so.
cheers
Mick
cheers
Mick
Got a few pics this arvo that might show things a little more.
I have also included a pic of the hypercharger and custom pipes.
cheers
Mick
[IMG]local://upfiles/21019/EF5F3FC839B3480BB88DFD2EB18F615B.jpg[/IMG]
[IMG]local://upfiles/21019/EC64220B736B4E72AB09E596419418C0.jpg[/IMG]
[IMG]local://upfiles/21019/F5BE7EDC942547E3B4B099FDFCF867DC.jpg[/IMG]
cheers
Mick
just a point on the 6" bars- you will need to drill ant tap a couple of holes and insert some bolts for endstops as the bars will hit the dash/ tank. The 8" bars clear this as long as you relocate indicators which is where all this started.
cheers
Mick
[IMG]local://upfiles/21019/A36E49E5502045D78A70ED726E020E81.jpg[/IMG]
[IMG]local://upfiles/21019/554F14CB5157431B927100076C82CF40.jpg[/IMG]
cheers
Mick
