clutch control lever swap out
Old 02-10-2013, 08:10 PM
cruzomatic's Avatar
cruzomatic
cruzomatic is offline
Default clutch control lever swap out
I'm installing new levers and finished with the brakes lever, easy enough. Now with the clutch control lever, according to the manual it states I have to drain the tranny fluid? Is this right. Was thinking it would be an easy swap out??
Old 02-10-2013, 08:14 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
If all you're doing is the lever, just relieve the cable at the adjuster and take the pin out at the perch. No need to drain the trans unless you're replacing the cable.
Old 02-10-2013, 08:16 PM
cruzomatic's Avatar
cruzomatic
Yup, all I'm doing is the lever.
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
dafuq? for the lever only? No.. if you're replacing the entire cable you need to, because the cable ends in the clutch housing cover on the transmission. Just skip to the part where you loosen up your clutch cable (those lock-nuts and stuff in that rubber cover on the cable about a foot and a half below the lever...), then remove the mirror and do all that stuff that holds the lever in and swap them out.. it's easier than the brake lever
cruzomatic's Avatar
cruzomatic
after relieving the pressure, just tighten it back up?
Old 02-10-2013, 08:17 PM
cruzomatic's Avatar
cruzomatic
Ok, cool, I'm headed back to the garage...be back in a few!!!
Old 02-10-2013, 08:44 PM
cruzomatic's Avatar
cruzomatic
All, done. You guys were spot on...perfect.
Thanks guys, the new levers look much better. Ha!!
Old 02-10-2013, 08:46 PM
QC's Avatar
QC
QC is offline
Don't we get any pics for our efforts???
Old 02-10-2013, 08:52 PM
cruzomatic's Avatar
cruzomatic
haha...
ok give me a couple minutes.....
Old 02-10-2013, 08:55 PM
PowerDude's Avatar
PowerDude
PowerDude is offline
Good deal bro. How bout some pics of those new levers?
Quick Reply: clutch control lever swap out
