internal wiring handlebars
i got a 08 softail, & im changing the handlebars & running the wires internally. got the connector unpluged & im trying to get the 6 wires out of the connector so i can run the wires thru the handlebars. on the inside of the connector on top of each pin there is a hole I thought i could stick a threading needle in each hole & get the wires out of the connector one at a time. but this doesn't seem to be working. Is this the right place to unhook these wires from the connector? can someone chime in and let me know of how to get these wires out of the connector. I do not want to cut the wires & splice but if I have too I will...
Are you talking about the Molex connector or whatever they call it. I did this on two 08 softails last year. Did you pull the insert out a bit with a pair of needlenose before you used the sewing needle. I used a paperclip myself. I think I may have filed it down a bit. Some of them come out easy, some not so easy. Don't know why.
In this video, Vic (Hdforummember) pulls the insert all the way out. I did this accidentally on one of mine but it's not required. You only need to pull it out a bit. Maybe an 1/8" or so. Then, as I recall, you use the paperclip or sewing needle:
If we're not talking about the same connector, please disregard.
I'm glad it helped. Even with the service manual I would've been lost w/o the internet . Did my wife's Deluxe first, then my Heritage. Wild1 518s on both so fishing the wire wasn't that hard. Happy with the way things turned out but I'm not looking forward to doing another one. I don't know what model softail you have but if you run into any wire routing issues or forget how something went together let me know. I took alot of pictures so I wouldn't forget myself .
