Just finished the 103 w/andrews 54h cams!
Well guys I just finished putting a factory 103 jugs and pistons out of a street glide and an andrews 54h cam and .030 head gasket in my crossbones and WOW! What a difference.... I cant believe how hard this things pulls!
End Result was 89.1 hp and 105ft/lbs of torque....
Mods are: Big radius pipes with baffled cut down to like 4'', air cleaner, 103 jugs, andrews 54h cam, .030 cometic head gasket, chain drive, and Screaming eagle tuner.
Even firing the bike over you can tell the jump in compression... so far i havent had a single issue with having no decompression releases and it runs amazing. If your on the fence about this take the plunge!
