103 to 107 and cams?
Old Oct 27, 2011 | 01:55 PM
Rich67's Avatar
Rich67
Default 103 to 107 and cams?
Got a question for You Guys that get the #s. I currently have 103 and 254e cams have the SE factory cnc ported heads supposed to come in at 85cc that calcultes to 10.14:1static 9.22 corrected and 190.9 ccp.If I put in for the 107 it comes in at 10.44 static and 9.49 corrected and 198.1 ccp.I guess my question is would this be ok.was thinkin for know stickin with the 254's,and what would 1.725 rockers do for me. THANKS.
Old Oct 27, 2011 | 04:09 PM
sublime_ac's Avatar
sublime_ac
Andrews 54 is a nice cam for that setup... Check out GMRPerformance.com their dyno section should give you something to think about...
Woods TW-555 is another cam that will work good with your setup.
I am running 107" 10.5:1 with the Woods TW-408-44 and it rocks.
Old Oct 27, 2011 | 04:54 PM
sporacer's Avatar
sporacer
Give Tman a call He has some new 600 series cams that have been producing the same numbers you have with stock heads on a 103.
Old Oct 27, 2011 | 05:03 PM
qtrracer's Avatar
qtrracer
Get you roughly 4-5 hp
Old Oct 27, 2011 | 05:23 PM
Rich67's Avatar
Rich67
Been thinkin bout the t-man 590 or cr575 what to keep my tq low end to mid just wantin to get it right the 1st. time or close enough that I"ll stay outa the motor.LOL
Old Oct 27, 2011 | 05:40 PM
Indianspringsaz's Avatar
Indianspringsaz
If you already have the 103 posted above, I dont think it would be very cost effective going to the 107. It would be an increase but not enough to justify the cost, in my opinion.
Old Oct 27, 2011 | 06:01 PM
Rich67's Avatar
Rich67
Well your probly right but I need somethin to do this winter.lol.I'm going to go a different direction than the 254's.I want to try to get atleast 10 and 10 out of it,and I"ve even thought bout different cams and more headwork on my 103.
Old Oct 27, 2011 | 06:09 PM
Indianspringsaz
Heads and cams on your 103 would be a good choice. You know the exhaust will come into play. Depending on what you have now.
Old Oct 27, 2011 | 06:11 PM
Biggzed's Avatar
Biggzed
Change your gearing and it will feel like you picked up 10/10. Lot less money and fuss too.
Zach
Old Oct 27, 2011 | 06:26 PM
qtrracer's Avatar
qtrracer
Those 254e cams are fairly short duration, you could put cams that have in the mid/upper 240's duration and maybe get a nice gain , keeping the lift reasonable(so you can leave valvetrain alone) and the ic early(44 or earlier) you might not lose too much low and gain a bunch of mid and it just might pull real good till the limiter. Just a thought.
