Air Horns and Relays
I am looking at some different air horns (I already have a wolo bad boy). I'm not unhappy with the bad boy but wouldn't mind something more powerful. I am also looking to either seperate it (the horn from the compressor) or find another type of air horn that may fit on my bike better.
I did not install a relay when I put on the wolo bad boy...I mounted it on my swingarm. I have a swingarm bag now so I had to move the wolo... but I'm wondering if I should have used a relay? I read that it was "plug n play" and saw where some said they ran it straight to the stock horn wires but others have used the relay.
My question is, what does the relay do and is it necessary even if it works without one? I am an idiot (in general) when it comes to electrical so I have no idea what the relay does.
the relay allows the trigger wire (from horn switch) to be less capable (smaller) that required to run the pump.
In a typical horn circuit the switch is rated for under 1amp. Most air horn pumps require closer to 5amps to produce enough air to be loud. The relay allows you to use a higher rated feed wire and still utilize your lower rated switch to trigger it.
Yes the relay is needed.
I installed my Wolo without the relay, after reading here that some other people had done it without problems. Don't know yet if it will eventually fry the switch, and also didn't check to see if it might be a little louder with the relay and heavier wiring.
If you come up with something significantly louder, please post. People seem to hear the Wolo fine, but what I'd really like is if they krapped their pants. That would be my revenge for them sleeping while driving, and trying to kill me. LOL
The same was true for mine. It was marketed as plug 'n play (which it wasn't) but I used a relay.
I'm not sure you will find an air horn more powerful than the Wolo bad boy. You may want to consider mounting your horn between the front legs of the frame where the upper bolt of the engine guard mounts.
That's where I have mine mounted. Just be sure it's tucked in enough that the fender won't hit it when the suspension is compressed all the way.
Another option with no relay http://www.thepropad.com/mini-beast-horns/
I may try to install the wow on the front down tubes somehow. I'm thinking if I separate the compressor and horn I should be able to get it on there. I even thought about just zip tieing the compressor to one of the down tubes and then mounting the horn under the stock cowbell and mounting it off the top frame mount up near the neck. I think there is enough clearance for it but not positive.
