Installing Mustang Solo seat on 2013 Fatboy?
Hmmmm the seat caused the electrical malfunction?? I just mounted a Mustang Wide tripper solor on my '14 FatBoy 2 weeks ago and have about 850 miles on it. Just got to make sure when you install it that all the electrics under the seat are properly stored like they were at the factory. If you installed the seat and did not check that, it cause cause your problem. Not sure I'd blame it on Mustang. Mine is just fines.
Ecm contacts crunch from Mustang Sport Solo
Hi: These are the photos for the wear to the seat pan and damage to the contact plugs. The seat installation is straightforward and the frame shows witness marks where the rubber pads touch off. Unless this Fatboy Lo was assembled differently, check your seatpan and see if there is any markoff on the underside pan,
leeanders
10-26-2013 02:46 PM
JR Ryder
03-26-2009 10:26 PM
