Just purchased a 2014 CVO Breakout... and wanting to reduce the rear fender height... Have been cruising the HD forums for some time now... Gathering great info on things I want to do.... Quick question on the mounting the SS on BO with ABS.... anybody did one on a CVO BO..? Thanks
I'm sure folks have however there is no difference between a CVO vs NON-CVO.
Go check out the CVO Forums if you want to see though:
Got it... Thanks HarleyCharley.... Just wanting to see about the ABS mounting issue that was being discussed.... earlier... still learning to navigate the site...
I put one on my breakout with ABS a couple weeks ago. It is pretty easy, the compressor just mounts off a bracket that hangs off one of the front shock bolts. Everything is a pretty tight fit but it fits.
Hey Joe...if you have a pic of the mounting of the compressor...I sure would appreciate it....thank you....Don
