lowering kits (collar kits)
I used the Dead Creek lowering kit on my Deluxe. Works great, easy to install:
https://www.deadcreekcycles.com/No-S...Kit_p_704.html
this is the second bike i have installed the dead creek collars on. wish i had the money for a shotgun but 80 bucks work! i'm 220 and find that taking the preload on the shocks to 2 turns, smooth out the bumps a lot better. FYI, I hear should lower the rear before the front. so get those collars on quick! front should be same height or higher than the rear. correct me if I'm wrong.
Is your profile pic with the collar kit? if so how much did you lower it and if I could bother you for a side picture thanks
It is my current profile pic with the collars. I used the 2" collars it also comes with 1.5" kit. I just installed my shotgun so these are off the bike. PM for more pics
Not trying to thread jack you but I was wondering if anyone had ever used the eBay lowering kit? It's just a bolt setup I believe.. Not really sure but it was only like $14 so I figure it couldn't hurt to ask about them. I'll spend the $80 on the dead creek setup but if the $14 ones are just as good then I'll get them and keep saving for the shotgun shock. And another question while I'm here lol... What's the difference between the progressive original kit and the drop in kit other than the obvious about not needing to disassemble the front shocks. Should I spen the extra couple bucks and not need to disassemble or is it not worth it.
