Oxidized Polished Aluminum
So whoever owned my Rocker C before me really didn't take great care of her. They put a couple very nice, very pricey mods on. But they did a terrible job of actually cleaning her. I've accepted a few issues with the denim paint. Not a big deal. It's to be expected. But I do not accept polished aluminum wheels with oxidation spots!
Do I have any good options to remove the oxidation and get them looking fresh again? I cleaned them today with the Wizard stuff Harley recommended. Throw me some ideas, family.
Really easy for you to learn how to find an answer. with me having to type a lot..
I learned it the hard way... now I'll pass the easy way onto you NewBe's....
CLICK below...
http://lmgtfy.com/?q=remove+oxidation+from+aluminum
CLICK below...
Never-Dull
I used a product called Never-Dull on my rescue Sportster. It is an old fashioned cloth "wadding" and comes in a metal can. It's is about $4 at Farm & Fleet or other similar stores. It is better than anything else I've tried on light to medium oxidation.
For the heavier work I bought a metal polishing kit from Harbor Freight. It has 3 clay bars and a set of wheels.
A rainy afternoon of work and my cases went from gray to looking almost like chrome.
Oxidation is a bitch sometimes. If it is light, the best way I have forund is Mothers Mag Aluminum Polish and several clean cloths. Every time you polish, clean well before you put more on. Just keep repeating until you get the desired shine. If it is actual pitting, pull the rim and wet sand the areas lightly until you get an even dull shine on the whole rim. This can take forever!!! Then polish to a chrome like shine. Its a pain, but once you get it to look like chrome, get the rim cleared. Then you only have to go through that once. Last rim I did, I had to sand then buff the rim several times to get it to look real good. If you don't want to go throught the clear process, you will have to polish often, and keep a good wax on it to protect it. Carnuba paste wax has always worked best for me. Good luck man, it is alot of work, but well worth it.
Be careful, I used metal cleaner, which is great for bare aluminum, on a coated part on another bike and it wrecked it...
To make my rear wheel look almost new, a buddy of mine has a polishing wheel and jewelers rouge/various grits. In about half and hour it looks great. Good for a couple years if you keep after it.
A buddy told me about some honda spray polish which I bought and works great! Keeps brake buildup and dirt to a minimum plus shines the wheel
Ps check your wheel bearings to make sure they are ok, I had 2 failures in 13k...last one at 65 mph...They are cheap to replace, Timken and allballs make good ones...Enjoy your rocker, they are great bikes once you set them up for you.
07 fatboy wheels aren't clear coated either. they are now though, I had them polished to the 9th degree then cleared by a local wheel repair company called Transwheel.
now I haven't seen all factory polished aluminum wheels but of the hundreds or so I have seen not a one of them had clear on them from the factory, which is ridiculous in my opinion.
