Need Taller Gearing-2014 Custom 1200
I've mostly been riding Japanese and European V twins & Sport Cruisers. Most of them including the Moto Guzzi were shaft driven.
The problem with the 1200 is the max torque is right at 3500 RPMs or a hair under 75mph.
The speed limit in some parts of Texas is 85, while in my area its mainly 75mph. No one does the speed limit around here, so I find the 1200 a little buzzy on the open road.
What are my options for changing the sprockets for taller gearing?
HTH.
Sorry, don't have a tach but it should be in the range 3250 -3300. The bigger the transmission sprocket the lower the RPM, so the math says:
At 70mph in 5th gear:
With 29 teeth (Stock) sprocket it is 3400 rpm
So with 30 teeth, it is 3400 x 29/30 = 3286.67 rpm
Can someone else with a tach please confirm that. I have a 2007 XL1200L, all stock engine except for the 30T transmission sprocket.
Thx.
Thx.
You don't really need to "tach" a pulley change to figure out the difference, it's pretty simple math.
Going from a 29 tooth to a 30 tooth tranny sprocket:
29/30 = .96666
If with a 29 tooth at 70 MPH the RPM is 3400, then with a 30 tooth:
RPM * .96666 = the new RPM
3400 * .96666 = 3287
Or, a ~3.5% reduction
29/30 = .96666
mrbreezeett1 (02-24-2020)
Thx.
Thx.
Oop's, got distracted while posting. Yep, that's correct.
Ive got a 32 tooth front pulley that I got for my 883. It was just a little too much for that little engine that could. I sell it to ya fro $60 plus shipping. Heres where he sells his new ones.
http://www.ebay.com/itm/Sportster-32...item4d18ccc297
