Sportster Missing at cruise speeds
Old 12-15-2014, 06:20 PM
STRETCH FLHX's Avatar
STRETCH FLHX
STRETCH FLHX is offline
Stage III
Default Sportster Missing at cruise speeds
OK, I've just acquired another HD. This one is a 97 Sportster 1200.
I had it out over the weekend and at cruising speed (2000-2500rpm)
it kept popping/backfiring. Seems to idle just fine, and when I get on it, it wants to come out from under me and pulls hard until I let off.
It has a stage 1 kit in it (best I can tell from air cleaner & ignition module), power cones in the exhaust and originally had un-baffled factory exhaust. I just put a set of Bassani Radius pipes on. The bike did sit for a while before I got it, and I ran some fresh fuel in it.
Does this sound like a carb problem, or should I look elsewhere ?
Old 12-24-2014, 11:03 AM
mad jak's Avatar
mad jak
mad jak is offline
what ur spark plugs look like since it been sitting for awhile and make sure they are gapped to .40 i aquired a used sporty a couple of weeks ago the plugs was not gapped bike was all over the place put in new ngk plugs and gapped then off i went cruising
Old 12-24-2014, 01:35 PM
Mick's Avatar
Mick
Mick is offline
If it only happens at a cruise , the easy thing to do is to pull out the choke ever so slightly and see if it feels better.
If it gets better , the bike is lean at that point in the throttle range.
Try cruising at a higher speed and RPM , lets say 3,000 RPM and see if you still have this problem.
At a higher speed and RPM , the needle will be higher in the carb , if it's OK then , you should shim the needle.
To shim the needle , pick up maybe 3 #4 machine washers (home depot , lowes) install 1 or 2 under the jet needle (to raise it) and retest.
Shimming the needle brings in the taper part quicker and transitions to richer at a lower point in the throttle position.
The pipes you have are VERY free flowing and may need a bit more fuel at that point.
If you take the carb apart , let us know what jet combo you have , the stock carb is very easy to tune well.
Welcome to the Sportster Forum.
Mick
OneHarleyAtATime
EVO
45
09-23-2021 07:56 AM
Trevor Noyes
Carburetor Related
05-21-2019 07:55 PM
OneHarleyAtATime
Carburetor Related
06-11-2017 05:09 PM
smellsbad2
Engine Mechanical Topics
08-18-2011 02:08 AM
NakedSnowman
Exhaust System Topics
01-15-2008 10:11 PM
Quick Reply: Sportster Missing at cruise speeds
