09 Nightster Starter Engages On Its Own
My starter engages without pressing the start button, and runs intermittently while the bike is running, causing a grinding sound. I have no diagnostic codes for this issue. (I know it is the starter because I turn the key to "run", the start switch to "run", and the bike starts without pressing the "start" button).
I have the switch housing apart, but cannot see anything there (water, corrosion, etc). I am stumped and frustrated. Please reply if you have ever heard of this issue. Thanks a bunch.
One of the black relays in the fuse box is for the starter, check there for corrosion first and maybe swap the two relays and see what happens.
If it's still the same try disconnecting the wires at the start switch and see if the problem persists, if it's still doing it at least you know it's not the switch, if it solves the problem you know you have to change the switch.
It's either that or take it in to your local HD dealer or Indy and get charged out the *** for labor.
You can do it. Just take your time and go slow.
If the problem wasn't in the relays and the switch is Ok then it's going to be a short somewhere in the harness.
Good luck.
Once you remove the wires from the switch try to start the bike by touching the wires together (untouch them as soon as it starts), if it runs normally without the starter trying to engage then you know it was a problem with the switch, if it still tries to engage the starter then as Thunder says it must be something in the wiring.
