XR1200 exhaust fit a Nightster?
Old 04-10-2015, 04:07 PM
KNIGHTSTER5's Avatar
KNIGHTSTER5
KNIGHTSTER5 is offline
Question XR1200 exhaust fit a Nightster?
Will it fit without any major modifications?
Old 04-10-2015, 05:15 PM
Mick's Avatar
Mick
Mick is offline
Not too sure , but all the exhaust listings I've ever seen stated "all except XR models"
I would have to think the mounting bracket setup is different on the XR bikes.
If I could just steal a set , I'd try it for giggles , but I don't mind a bit of fabrication now and then.
Mick
Old 04-10-2015, 06:59 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
should be an issue. you'll just need to fab up a hanger for the rear portion.
Old 04-11-2015, 09:02 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Red face
If you mean the stock system this is a side view of an XR. It will probably fit your bike, however there is the small matter of where you put your right footrest and rear brake!
Old 04-11-2015, 07:38 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Yes but you will need to make two brackets. One at the rear. Any strap steel with a hole for a bolt at one end and a hole at the top to bolt on the rear fender brace. The second one in the same manner.
I did it on the XR itself as the front bracket serves as a overly heavy passenger peg and I set the bike up solo. The end cast bracket was also too heavy. I used long handled wrenches and cut the ends off. Chromemoly (sp) is tough to drill.
Old 04-16-2015, 03:35 PM
KNIGHTSTER5
Thanks for the replies I realized that the mount for the foot controls would be blocked by the pipes. Looks like I'd have to put rear sets on where my passenger pegs are. Not worth the trouble. I was looking for a cheaper alternative to D&D bobcat or RSD slant 2 into 1.
MarkFXSTC
10-09-2015 12:03 AM
jraustin
Engine Mechanical Topics
08-30-2010 12:56 PM
hoodlumkurt
12-07-2009 03:36 PM
chunks
06-28-2009 09:12 AM
martinez_nc
01-26-2008 06:14 PM
Quick Reply: XR1200 exhaust fit a Nightster?
