Bike Is Dead, Won' t Start. NEED HELP!
Old 04-23-2015, 08:24 PM
shane_moto33's Avatar
shane_moto33
shane_moto33 is offline
6th Gear
Default Bike Is Dead, Won' t Start. NEED HELP!
Alright fellers, seems to me that I had the dreaded fuel system relay crap happen to me recently, but I can't be sure... About 4 days ago I was cruising down the freeway doing about 75, and my bike throws the Check Engine light on, and the motor winds down, no more throttle. I shift down two gears, get in the right lane and it cuts out completely. So I ran the Diagnostic codes and came up with the following.
P0261 Front Injector Open/Low EFI
P0263 Rear Injector Open/Low EFI
After that, my buddy and I loaded the bike in his truck, and took it home where it now sits. Now, I have not tried anything like swapping relays, I just started doing research. It sounds like this could be the issue... If anyone has any suggestions, I'd appreciate it. Being bikeless is a feeling I do not like.... Needing some suggestions guys... Thanks!
PS my bike is a 2009 Sportster 1200 Custom.
Old 04-23-2015, 08:27 PM
bullast's Avatar
bullast
bullast is offline
So...
This EXACT event happened to me the other day.
Id done a few electrical mods on my bike in the recent past.
Make sure the Neg terminal on your battery is snugged down.
Thats all I got.
Old 04-23-2015, 08:29 PM
Guzzi's Avatar
Guzzi
Guzzi is offline
As with all EFI bikes, check battery connections and voltage.
Old 04-23-2015, 08:38 PM
Cool Inferno's Avatar
Cool Inferno
Cool Inferno is offline
Start by checking the fuses and swap the relays. Check for corrosion on the relay and fuse contacts. As far as relays, I always carry a spare one tie wrapped in the fuse box area because when they go your done for the day on the side of the rode.
Old 04-27-2015, 12:30 PM
shane_moto33
6th Gear
Well I got new relays installed, and put dielectric grease on em, and still no luck. Won't start. So i checked my battery terminals made sure everything was tight, and still nothing. just that annoying click. So then i hooked her up to some jumper cables, and she would crank and crank, but wouldn't turn over. But here's the weird thing, the entire time, I never once heard the fuel pump prime. I never heard it make that whirring sound it usually does... Is it a bad battery? A bad fuel pump? I'm out of ideas
Old 04-27-2015, 12:38 PM
bullast's Avatar
bullast
bullast is offline
Did you try to jump off of a car? If so, your battery is prob toast.
I recently did that and fried my battery... like a dumb**... yea yea
Another stupid thing Ive done and seen is trying to start the bike without flipping the "run" switch to "on."
Its gotta be something simple.
That big fuse inline from the battery is ok?
Old 04-27-2015, 03:55 PM
Outtakes's Avatar
Outtakes
Outtakes is offline
Get a Factory Service Manual and a Multimeter. Dont leave the car running while trying to jump it or it will ruin the battery or other parts. So then i hooked her up to some jumper cables, and she would crank and crank, but wouldn't turn over. If its cranking its turning over, if its clicking its not.
Old 04-27-2015, 04:37 PM
shane_moto33
6th Gear
Yeah I tried to jump it off of a running truck, and I'm hoping the battery isn't toast, but I'm going to pull it out and have my local shop test it.
I did look at the other fuses and relays in there was white powdery stuff in there and a bit of corrosion, but not too bad. How do I clean that? And should I replace all the other fuses etc?
Now, how exactly do I test it with the multimeter and the Service manual? I'm not familiar with EFI since I've always had carburetor'd bikes.
Old 04-27-2015, 04:42 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Jump starting from a car will not harm the battery on the bike (on modern bikes with electronic devices, don`t start the car engine).
Old 04-27-2015, 04:51 PM
Outtakes's Avatar
Outtakes
Outtakes is offline
Manual from HD Dealer or Ebay ( get the HD one) You can get a meter online .
(Amazon ect.) U Tube has lots of videos on how to use it. You can check your battery and
engine sensors.
Quick Reply: Bike Is Dead, Won' t Start. NEED HELP!
