A lot of the coil relocation kits bolt in the exact same place that the bracket at the horn on my Seventy Two. Has anyone with the cowbell horn just taken the horn off the bracket and modified it to screw the coil on to it?
i considered that for a hot minute but decided to use a piece of alum. stock to get the coil up a bit higher. also made a set of cotton braided spark plug wires
I used the stock coil bracket from a 72 with a tab welded onto it to
mount the coil lower. I dont like the plugwires stretched when
the coil is mounted higher, so mounting it a bit lower puts no
stress on the wires at all. Here's an old picture.
hope this helps,
T.
Reason: insert picture
