2002 sportster 883 won't start!!!
Hi there. I'm new to this forum and was hoping someone could help me out. My 2002 sportster will not start. It just turns over and occasionally backfires. It has a new battery and new spark plugs as of about a month ago. It started perfectly last night, I rode it ten minutes down the road to a friends and it just wouldn't start again. It was late so I didn't want to wake the neighbors so I left it there overnight and tried again this morning. Still just turning over and backfiring. Any ideas would be greatly appreciated. Thanks in advance!!
Steve
Steve
Since it ran well to your friends house, I would be inclined to believe your problem is electrical. Check your plug wires and make sure that they are routed to the right cylinder. Some comedian could have inverted your plug wires at your friends house. Check battery contacts and fuses. Also check your ignition module connections. Just a starting point as to what I would check.
Backfiring out the exhaust or the carb? ,are sure you have spark. You need three things to run. Fuel, spark and compression.
I'd starts by looking at the plugs. Then plug wires. Then coil. Then ignition module.
Another thought outta left field. The bank angle sensor shuts off the coil. If that sensor is bad it wouldn't start.
