HD Quarter fairing 57070-97DH- install tips?
I haven't fit the HD fairing, but it get's a lot of use in the Dyna section. People seem to like the quality.
My fairing is just a cheap Ebay fairing. It cost me more to paint it myself than it did to buy it.
The clutch cable will need to move as you indicated. Depending on your bars and riser combo, you may have to loosen the banjo fitting at your brake lever and turn it to a different angle. If you have generally wider bars, this may not be an issue.
My throttle cables tucked inside the fairing, but I think the HD fairing has more meat at the lower edge protruding rearward. You may have to deal with the throttle cables, but I can't really speculate.
How do you disconnect the clutch at the handle bars to move it outside the forks? I know how to loosen it but I can't figure out how to take it off the handle bar part to relocate, Ive been searching and searching for a video instructions or picture. any help would be great
