06 883 r exhaust studs
Old 07-31-2015, 11:53 AM
curtisjames91's Avatar
curtisjames91
curtisjames91 is offline
2nd Gear
Default 06 883 r exhaust studs
I just picked up a 06 883 r off a friend and have been trying to make it my own but when I got the bike one of the exhaust studs was broken in the rear head and he had put a bolt in the other side of the rear well riding it yesterday one of the nuts on the front head rattled off and I can't get a nut to go back on so I think I'm gonna pull the stud and use a bolt but my question is... Is this a common problem? Am I gonna be ok with using a bolt? And will an 07 head work on my 06?
Old 07-31-2015, 02:17 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,645 Likes on 1,135 Posts
A stud and nut would be the best repair IMO. They make a tool that (JIMS) that bolts to the good stud, so you can drill out the bad stud. Or, remove the head and have a professional shop do it. Depending on what stud broke, it may not be that accessible to drill while head installed.
Loose exhaust nuts are common but not a chronic issue. I've not lost one in 25 years of owning my bike. Just don't tighten them too much or you'll be back with a broken stud. I'd recommend some high temp antiseize grease when installing.
John
Old 07-31-2015, 10:24 PM
curtisjames91
2nd Gear
Thanks for the reply I'll look into that tool because someone has already tried to drill the old one out and it's pretty chewed up that's why I asked about the 07 head looks like a 3 year old ran loose with a drill lol
Old 08-01-2015, 09:39 AM
John Harper
Not sure about the '07 heads. They made the fins bigger on the heads and cylinders sometime around that year, I think. Doubt mismatched heads would look very good on your bike. And, the '07 EFI heads might not mate up with your carburetor intake manifold.
John
Old 08-01-2015, 01:47 PM
curtisjames91
2nd Gear
That's what I I was worried about seeing as they went to efi in 07 thanks again
MURPHCC1
Engine Mechanical Topics
02-12-2018 01:23 AM
mar-tay1
Shovelhead
08-16-2012 10:18 PM
twiceretired
10-24-2011 10:49 AM
BigJim8765
Exhaust System Topics
13
02-08-2010 12:20 PM
janiharley
11
11-10-2009 02:53 PM
Quick Reply: 06 883 r exhaust studs
