Anyone made there own coil bracket?
I'm going to make my own tank lift and bracket for a coil and ignition relocate. I know how I will make the tank lift already. I've read a few posts on them. Haven't had much luck finding much on a bracket for coil. I have an idea to use cardboard to do a mock up but would like to see how others have done it.
No pictures to offer, but you can make brackets to put just about anything just about anywhere with flat steel by drilling holes and making right angle bends. Cardboard mockups, like you said, do really help. And it won't really matter if it's on the ugly side, the bracket will most likely be rather small and rather well hidden.
Location: In the foothills of southwestern NC - US of A
'Not a coil bracket, but similar enough in purpose, is a bracket I fab'd out of .062" stainless steel sheetmetal, to mount a stainless steel breather assembly that I dreampt up for my '09 Iron. See the forum link below for the assembly in different stages of completion:
https://www.hdforums.com/forum/sport...ather-mod.html
The design was born out of the pre defined factory bolt pattern dimensions of the pushrod tube bases, and the allowable clearances surrounding these holes. It was a simple matter of removing the two opposing fasteners from cover to cover to get a center to center dimension, then with the consideration of the size/dimensions of the small filter I wanted to use, use a piece of cardboard to simulate possible configurations, height, the space off the engine, etc. Within 10 minutes or so I had a template that I replicated in thin aluminum trim coil so it would hold its shape and would allow me the ability to make minute changes in angle and center to center for the bolt holes. When I was satisfied with the results I replicated the bracket in stainless, then focused on the lengths and angle of the bends for the .375" OD stainless tubing that was to run from the "U-Tube" exiting the breather ports of the cylinder heads down to the breather.
You should be able to use the dimensions provided between fasteners of the cylinder head bracket in a similar fashion to come up with a suitable bracket to support your repositioned coil.
=8^)
=8^)
