Stage 1 air filter upgrade on my 2014
V&H Straightshots, FP3 tuner and a high flow K&N filter installed.
I've been looking at ways to eliminate the crankcase air flow yet keep my stock filter housing so this is what I came up with. Not much room behind the filter without finding a way to make a short sharp 90 degree turn.
I found that the distributor ends of a new spark plug wire set fit perfect and tight. Finding the right connectors was pretty easy and it all fit well although I used some zip ties anyway. I'll check this all out after riding some next season to see if the oil has much effect on the rubber parts.
I few big holes drilled in the backside out of sight and the test ride today was awesome, even while it was snowing.
