Cvaria's 2007 883 Standard (XLCN): Consolidated Thread of Nonsense (Working)
Old 02-18-2016, 12:26 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
Default .... Max Freegrant - Epic Session 039
ridge for internal circle clip (13) is now visible
internal circle clip (13) inserted into ridge
dust seal (12) added
6mm torx screw (18) and washer (17) lightly screwed into bottom of fork, throt damper sleeve and into damper. used the progressive spring to apply pressure to the damper from inside the tube to keep it from spinning while i was installing crew (18) and washer (17)
progressive spring in tube...
progressive washer on spring
uncut progressive pvc spacer (no cutting for my 2007 xlcn)
Tube cap lightly screwed into fork
drain screw and washer (19) added
done for now
Old 02-18-2016, 01:31 AM
cvaria's Avatar
cvaria
cvaria is offline
Default Ground down nub on RH brake caliper boss per Ness instructions:
Ness big brake needs the older caliper boss nub ground off to avoid rotor contact.
dremel tool ripped it right off.
Old 02-18-2016, 11:55 PM
cvaria's Avatar
cvaria
cvaria is offline
Default almost finished
picked up powder-coated parts
mounted sprocket/pulley
blah blah
blah blah
done
mounted rotor
blah blah
done
grabbed new slider caps
added oil to forks
done
mounted forks
mounted lh ness adapter
mounted rh ness adapter
What!?
Old 02-27-2016, 11:18 PM
cvaria's Avatar
cvaria
cvaria is offline
Talking
mounted front wheel with new disk
assembled goodridge SS dual brake line
wrong... but, didn't know at the time. the line didn't come with instructions
took off single line and master cylinder.
rebuilt ebay dual disk 11/16 master cylinder
used hd rebuild kit 42809-04
done
purged the RH caliper with denatured alcohol
lol , awesome clip Singham 8.. best action scene with car stunt .HD.mp4 - YouTube
Old 02-27-2016, 11:38 PM
cvaria's Avatar
cvaria
cvaria is offline
mounted 11/16 master cylinder and line. put in fluid and ziptied the lever to the grip
two errors here but it was 1 am...
mounted rear wheel
added new pads
pulled old soft line
mouned goodridge rear SS line. bled
proud moment ruined by the sudden realization that the front brakes lines were backwards... huh?
F******************K
Cvaria's 2007 883 Standard (XLCN):  Consolidated Thread of Nonsense  (Working)-ktmuaoj.gif
Old 02-28-2016, 12:13 AM
cvaria's Avatar
cvaria
cvaria is offline
Wink
back up on lift... to fix the lines and got fed up with the mismatched sliders... sanded and polished the RH slider to mirror finish like the LH slider.
adjusted lines. corrected master cylinder to tee line. transposed the left and right front brake lines.
***see that shine?! those sliders are NOT chrome... that is stock+elbow grease! hot damn!*****
brakes done!
feels good!
but...
Old 02-28-2016, 12:38 AM
cvaria's Avatar
cvaria
cvaria is offline
Default Grenades appeared
off with the beastly eagles
blah
done. 10x easier than anything i've ever done to my sporty.
they are NASTY! they are LOUD. ignorant loud. i love them. no question. even considering them for my other bike.
i posted vids below with sound. there are very few vids with sound out there... the vids don't do the sound justice. rumbling like thunder, bass, and raspy. insane
i was going to do chrome heat shields, called vance and hines 4 times and they just couldn't find a price for the shields and never returned my calls... sad but, true had to email corporate, $169 for rear and $192... 360+? that's almost half the price of the pipes. nope
  • (-)been a pain in the *** to tune. power vision reads 99 in tps[1][1000] and tps[1][1500] on every run, even if the bike is just idling.
  • (-) shakes my rear brake pedal and it taps my foot varies based on year as the rear master cylinder moved on newer bikes
  • (-) pipes sit out higher and farther from bike
  • (-) blocks passenger pegs... no issue for me, have none and never will
  • (-/+)low end torque has rolled out {gone}, bike now likes to be in higher revs, and is twitchy in lower revs.
  • (+)but, the loud pipes save lives is hella true with these things. cars way ahead are reacting to the sound (not merging or aborting merge)
  • (+) looks great, shows off freshly powdered and polished rear pully/sprocket and chrome guards
v&h grenades:
first run/fire up... bad... untuned, smoke is anti-seize on the o2 plugs and first run pipe goodness (normal):
after PV 3 runs
grenades vs seII:
Old 02-28-2016, 01:14 AM
cvaria's Avatar
cvaria
cvaria is offline
Default License Plate Relocation
scope creep went from a second rotor to new pipes, alarm, rear brakes, yeti campus stories, clutch cables, sand paper, polish, and now a plate relocation.
used:
hd relo kit- 60972-10
http://www.adventureharley.com/harle...e-kit-60972-10
ugly hole cover.. had to go
get that s*** outta here
used auto interior trim plugs from the auto parts store (o'reillys @ $2.29) to fill the holes until i find a better solution that isn't tacky like most of the skull/cliche/triangle crap out there.
done. will have to swap out the tail light for a non-windowed unit since the plate is no longer there. scope keeps creeping
Problems:
because the relo kit added more distance between the inside of the fender and the LH side, i had get longer bolts from ace hardware to continue using my quick detach hardware.
since i replaced the left side, replaced the right. painted the caps with nail pol... the vivid black touch up kit from my wide glide. huh? http://www.harley-davidson.com/app-c...ts/-J04703.PDF
before
after
Old 02-28-2016, 07:22 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,236 Likes on 1,812 Posts
Content
Comedic Relief
Old 02-28-2016, 10:50 AM
cvaria's Avatar
cvaria
cvaria is offline
Content
Comedic Relief
lol. yeah, tons of negative rake in this thread
Quick Reply: Cvaria's 2007 883 Standard (XLCN): Consolidated Thread of Nonsense (Working)
