FXDXT retro T-Sport Saddlebags on Sportster?
You already know where this thread is! What more do ya want?!
Thanks. The signals stick out about 2.25 inches beyond the widest part of the fender, right about at the bottom lip of the fender. I'm hoping, since my mount bolts will already need to be 3/4" longer than the usual since my sissy bar mounts in the same places the bags do, that it will work. Too much money to not be certain first....
Here are a couple of views, from the side and top. At their closest and most rearward the bags are 9 3/4" apart. My rear spacers are 11 5/8" wide, so you can see that the backplates are shaped towards each other at their lower rear parts. That is probably to help strengthen the backplates, it also helps disguise the presence of the mounting metalwork. My front spacers are wider apart, so the bags don't press against the seat, which means the bags are toed inwards at the rear, as you can see in the top photo.
Hope that helps!
Hope that helps!
WVDevil (04-18-2016)
