2016 48 Tire swap
2016 48 Tire swap
I just want to be sure and verify if a shinko 270 Classic tire can work with the solid wheel on the 2016 48. I am thinking about swapping the front and back with this tire.
My only concern is running a tube since the tire is a tube type and how that works with the stem. I know typically with Mag wheels you want to run a tubeless tire.
Help is appreciated before purchasing.
Cheers
Cheers
Thanks. I think my question was more directed to switching to a tube tire and using the tube with the cast wheel. I know I will need to run a tube but can I take the vavke stem out for the one that comes with the tube?
Not seeing inside the wheel yet but is the valve stem attached to the rim via bolts where by you can take it out?
Cheers
Cheers
Cheers
Cheers
