XL1200C brake upgrade question
Hi All,
Is it true that 42943-08 (Front Left XR Brake) bolts right up? Anyone done this? Can you verify it bolts right on and more importantly, that braking is improved?
Also, if I end up doing that swap I'd likely go to SS hose since I'd be draining anyway. Any links to where to obtain an affordable solution for that?
Last question: any similar "simple/cheap" upgrades for the rear?
Thanks!
Thanks!
Brandon Sibley (05-27-2020)
https://www.reddit.com/r/sportster/c...liper_upgrade/
It has mag wheels though? Is that key?
It would still be just one caliper. Only the left. Here is a reddit post where someone did it on a nightster:
And yes, you could need a larger master cylinder if you want the same feeling of your brake lever.
deadrubberboy (07-05-2016)
spoke wheel would be to go with larger 13"~14" rotors (like from Arlen Ness)
with caliper adapters that move the caliper outwards toward the rim.
Disclaimers apply, I have not done the above, I used the stock cast wheel
on my OL's Iron.
larger rotors, any issues?
Perhaps look up your 1200C part number and see if it fits the XR to determine if it is interchangeable.
I just replaced my front caliper and relocated/replaced my rear with chrome calipers and to a larger matching SS rear rotor. I used parts from an earlier custom which was all bolt on.
I'm going to do the ness caliper swap to dress it up, and the 11.5 jagged rotor for better braking power in the rear,
Then the 15" front rotor for better power and again the ness dress up cliper.
