Small fork extension this winter
#72
Jiffy stand penny trick. I used washers. Who has a change jar anymore?
https://www.google.com/search?q=kick...ng+penny+trick
Why re-use the lower bushings? Do you plan on having the front-end apart, again, soon? Get new innerds. There is some springy-ness to the bushings. You can pry them with a screwdriver, using a twist, not a pry-action, to spread the bushings. If you're real particular, you could hammer a piece of Copper tubing flat to use as a prying/spreading device. Copper is soft. I've always simply used new innerds.
#73
#77
Received 3,940 Likes
You want to get the sag between 25%-33% with you sitting on the bike.
Start out with 3/4" of the spacer sticking out, then adjust the PVC length from there, as needed.
#78
Shorter spacer = more "bounce', right? Shorter spacer increases or decreases sag?
#79
More sag there is, more likely to bottom out. Also will feel spongy/wallow.
To little sag and when you hit a bump the tire is likely to leave the ground briefly (not good).
HERE is an informative Report on front suspension. It is TWO parts, make sure to read the 2nd Part.
They way I measure sag is as follows:
Determine how much total travel is available. ie. 3"
25% of 3" is 3/4", 33% of 3" is 1". So the sag should be between 3/4-1"
Sit on the bike. Measure how much the front suspension "sagged" from the combined weight of the bike and yourself. It should be 3/4-1" (if you started with 3" of total available travel).
If it is less than 3/4", you will need to shorten your PVC spacer. If it is more than 1", you will need to lengthen your PVC spacer.
#80
