Lower shock bolt looks alittle bent
Old 12-08-2016, 07:43 PM
gar187er's Avatar
gar187er
gar187er is offline
Originally Posted by Winweg12
Are you sure Ill be able to get them in straight without lifting the back end up? Thats my only concern
ive done mine before with the bike on the side stand... worse case you would need someone to stand the bike upright. Easiest would be to jack it up just a touch, but its definitely possible without.
Old 12-08-2016, 09:05 PM
hexnut's Avatar
hexnut
hexnut is offline
Isn't that a shoulder bolt. It will be straight when it buts up against the swing arm regardless if the bike is jacked up or not.
Old 12-08-2016, 09:13 PM
1BRAVO9's Avatar
1BRAVO9
1BRAVO9 is offline
Originally Posted by Back-n-Black
Come on man...It's like 50 out.
Ain't that the truth, you would think by the way the OP talked he lived in the Upper Penisula or something.
Old 12-09-2016, 04:42 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Lightbulb
If you leave the bike with all its weight on the ground, when you pull off one shock the other is now taking all the bike's weight and will sag, reducing the distance between the shock mounts. That is why some of us have recommended using a jack, to support the bike's weight, which also provides the means of adjusting the distance between the top and bottom mounts, to match the length of your new shocks.
Old 12-09-2016, 06:27 PM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
Come to think of it, you might not need to remove the bolt to tell it's bent. Turn the bolt 180 degrees. If it's bent, it'll point in a different direction. However, once you break it free, you gotta remove it to apply Loc-tite, or use some green, penetrating Loc-tite to secure the bolt, again.
Old 12-13-2016, 02:03 PM
Winweg12's Avatar
Winweg12
Winweg12 is offline
I was in Oxford, Ms when I was working on the bike. Much colder there. I have since replaced the shock bolts with new ones. Old ones werent bent but Im glad I changed them anyway. Got rid of those damn torx bolts. Plus the piece of mind.
Old 12-13-2016, 02:10 PM
Winweg12's Avatar
Winweg12
Winweg12 is offline
Already replaced them but damn good thinking
VazquezFXDP
10-25-2018 01:53 PM
HD48DK
03-09-2014 03:33 PM
SLV
03-06-2013 12:59 AM
rockon
05-23-2012 11:01 AM
strungxout
05-19-2012 04:36 AM
Quick Reply: Lower shock bolt looks alittle bent
