Do replacing header pipes make a difference?
I know the slipons vs full exhaust debate has been beaten to death, but I haven't found any full systems that I like. I currently have the V&H Straight Shot slipons installed and wondered if replacing the pipes themselves even do anything performance wise.
Received 2,189 Likes
Received 3,940 Likes
If your bike is stock or Stage I, changing out the headers will make no improvement, and sometimes are detrimental to power. The one exception is if you go with a good 2-1 system.
If you're looking for more power, install some Thunder Torque Inserts in your SS slip-ons, you will notice a marked improvement in low and mid range power, and save a bundle at the same time.
Not a flow dynamic expert , but noticed most . if not all aftermarket full exhaust systems do not incorporate the cross over feature like factor stock setup.
Believe the cross over feature either from the slip-on connection or near the cylinder heads with straight single horizontal tube or the new design just in front of the slip/on, serves to increase low end rpm torque and not high end rpm power.
Would prefer low end torque to high end HP.
Agree with DK that the 2 into 1 pipe setup is preferred on a stock or stage 1 setup , since it simulates the cross over feature.
If replacing my stock exhaust set up would go with the 2 into 1 pipe arrangement, but would probably have to install a fuel management system in 07 & up EFI fuel system to adjust the fuel to air ratio.
Not flow dynamic expert , but noticed most if not all aftermarket full exhaust systems do not incorporate the cross over feature like factor stock setup.
So a modern 2-into-1, especially with identical tuned-length pipes, will give better performance than the older style factory system with a balance pipe. The Buells are a case in point, as using identical length pipes enables the engine to be tuned to a much higher output than a stock Sportster. The recently introduced big-twin 2-1-2 systems are essentially a 2-into-1 with twin tail-pipes.
