Question about duel disk forks
Yikes... Holy Extendo, batman
It appears above that the sliders, wheel, brake cal and rotor were the originals for that 2000-03 "Custom" model
The forks in your second pic are 1999-earlier which use a sliding caliper that are the same from any HD model line...sportster, dyna, softail, Touring
You probably won't be able to use that 2000-later Narrowglide wheel in that 99-earlier fork because it is slightly wider so the caliper won't align properly with the rotor and the rotor bolts will rub the sliders
Received 2,189 Likes
The local Guru who I would trust with my soul looked at everything and TOLD her her best n wisest way to go would be to just sell the left overs n put stock back on instead of piece meal bits n pieces.
