Question about duel disk forks
Long story short to many hands before this parts have been taken off n lost. Her EX took it apart n left it.
That is going back to "Stock"
I understand if you want to keep the extended front end together for re-selling purposes (except for the wheel/rotor/caliper that you will re-use)
Simply remove the 99-earlier sliders and install a set of 2000-later sliders and reinstall the wheel/rotor/caliper (you may have a rotor spacer to remove if that extended front end was wideglide or midglide)
I have a "nice" 2000-later single disc slider set that would go right on
Did you mean to post the following in this thread instead of where you posted it here
The forks she bought plus the lowers won't match up . She bought it with some after market wide glide triple tree he has no idea who make it as it has no markings so we don't know what parts are needed there. The lowers are off a wide glide, and he was thinking we would just put the lowers on the 79 upper she bought but after looking everything over he lost parts and it's just a freaking disaster honestly. He has no intreste involved in any of the parts except to watch over my shoulder to make sure it put together right this time AND SAFELY, I went through the parts we had sitting there and wrote down everything he said. This brother is honest n straight up, it's hard to put into words what this woman and bike have gone through already from to many hands (trying to make do) if ya can understand.
Can you take some better/closer pics of what you have...I can probably identify the parts... Wheels, rotor, caliper, all sets of forks and sliders.
Here's what I suspect you have on the Narrowglide stock length fork...
Left (99-earlier) is what you have...Right (2000-later) is what you need and then can use all those parts from the extended frontend (wheel, rotor, caliper)
Here's the complete set of 2000-later sliders that I would swap for the 99-earlier...
those look a lot like what you posted?
are you saying she can take the lowers off and remount them to the uppers on the 79 upper?
Well, those are normal 2000-later, 39mm tube, 3/4" axle, sportster/dyna sliders (just like the one in my photo), but with extended 39mm tubes with a "Wide Glide" Style of caps that can be easily changed to the "All Other" style of cap.
how bout pics of the other stuff
More photos I'll get.
exactly what is wrote down....
Need 2000 sportster lower legs/axle/both spacers/and nut
caliper bolts/ crush washers for calliper.... (those I can pick up at the local shop tho)
sell wide glide tubes for $200 or trade for complete front end if possible.
"caliper bolts/ crush washers for calliper...."
Makes sense, it sounds like his plan is to use those parts to swap out the 99-earlier lower legs from the stock length front-end and then re-use the Wheel/rotor/caliper from the widened extend front-end...just like I said
...no big deal
Yeah, get more photos especially of the other front-end, I think it had an axle that you can probably use
