Another mod to share, I wanted a garage door opener for so long, I always keep the remote in my jacket but a lot of time I miss the button. All you need is a 4 terminals relay (5 is ok) and a garage door remote control. I tap the high beam wire to the relay terminal 86, white color according to the wiring diagram, terminal 85 to ground, terminal 30 and 87 to remote control switch circuit. Now when I hit the high beam switch, I activate the relay and join my remote switch circuit. Remote control costs $20, relay $5 + 2 beer labor. Not bad at all compare to $125 for the HD one. Cheers! Alex P.S. If you use a 5 terminals relay, just leave the 87a unused. You can also wire a momentary switch to join the relay solenoid circuit. I prefer high beam switch because it is easy to hit.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________ If it aint broke, fix it till it is. Click here to view my photos
06 FLSTFI/06 XL1200L(SOLD)/08' M.Benz ML320CDI/80' M.Benz 450SL
__________________
Trying is a valiant attempt at failure ...
'05 883L
V&H straights,taxes paid, chrome derby & gearcase covers,chrome headlight & visor trim rings, blue led accent lights,skull theme.Dragbars,6"risers,speedo&signal relo,skull grips.More to come...
Another mod to share, I wanted a garage door opener for so long, I always keep the remote in my jacket but a lot of time I miss the button. All you need is a 4 terminals relay (5 is ok) and a garage door remote control. I tap the high beam wire to the relay terminal 86, white color according to the wiring diagram, terminal 85 to ground, terminal 30 and 87 to remote control switch circuit. Now when I hit the high beam switch, I activate the relay and join my remote switch circuit. Remove control costs $20, relay $5 + 2 beer labor. Not bad at all compare to $125 for the HD one. Cheers! Alex P.S. If you use a 5 terminals relay, just leave the 87a unuse. You can also wire a momentary switch to join the relay solenoid circuit. I prefer high beam switch because it is easy to hit.
Dude, that's genius! I'm building one!
__________________
Dave
2006 Softail Standard
"Give a man a match and he will be warm for hours. Set him on fire and he will be warm for the rest of his life."
Genius? No way, I am not the one who invented relay and solenoid lol, I am glad that you guys find it handy. Make sure you turn off the high beam after you open the garage door otherwise you might drain the remote battery. This is how I did, arrive home, hit the high beam switch, my garage door opens, park the bike, shut the engine off and leave the high beam switch on position. When I go out again, I turn the ignition on, since my high beam switch was on before I shut off the ignition, it will send power to the relay and open my garage door. It's nice, isn't it?
I have attached a diagram.
