leaking fuel inlet
RE: leaking fuel inlet
be prepared...if it is like mine...
plastic is mounted to brass piece pressed into carb
plastic WILL break..and leave brass piece stuck in carb
real PIA to get out but it will come out..
i took a pair of visegrips and...twist..pull...twist..pull..hammer...curse... twist...pull
but it WILL come out...
replacement part is all brass...no more plastic..it will be fixed forever once it's done..
GL
GL
U can also break the plastic elbow off then stuff some cloth deep in the inlet port.. Tap the brass with threads.. Then use a long bolt same size threads a piece of metal pipe slightly bigger the the brass inlet a big washer and a nut.. Screw nut all the way to the head of bolt then slide washer on then insert into pipe then then tread onto tapped inlet and simply tighten down on the nut and presto uve made ur own inlet puller.. It really is a lot easier than it sounds
88Heritage_classic
EVO
05-16-2013 11:21 PM
