3.3 & 4.5 tanks interchangeable?
RE: 3.3 & 4.5 tanks interchangeable?
Somewhere, in the deep recesses of my mind (yikes!), I seem to remember that a 4.5 gallon tank swap will require a seat swap because of the longer "tail" of the bigger tank. Greater minds than mine on this forum can confirm or deny that for you. Good luck...
Thumper26
Thumper26
I too am doing a tank swap -- a 4.5 gal tank off a '04 1200C to my '06 1200R, which comes with a 3.3 gal. tank. Since I was planning on upgrading my seat anyway, I just ordered a seat that will fit a 1200C model (the 4.5 gal tank). You will also need the "Sportster Large Tank Installation Kit" (P/N 62999-04) which retails for $25. I ordered mine from ChicagoHarley.com for $20.
Note: If you buy a used 4.5 gal tank (like on eBay), be sure to get the gas cap included. The large tank's gas cap is a larger diameter up top than the one on the smaller tanks. It fits properly with the upper tank panel trim, the smaller ones don't, leaving a 1/2" gap all the way around between the top of the cap and the trim. A new one will run about $30 from ChicagoHarley.com. Hope this helps.
Cory: I recently changed from the 3.3 gal to a 4.5 gal on my XL1200R. As previously stated, it does require a seat change. PM me and I will give you the name and e-mail address of the small firm that repainted my new tank to match my original Yellow Pearl. I was very satisfied and the price was right. He is in Nashville, TN. ............. BC
ORIGINAL: Thumper26
I know all bikes are as individual as the owner, but the tank on the 1200R says Sportster all over it and I'd rather gas up every 100+ miles than swap it out. Just ONE of the reasons I got the "R".
ORIGINAL: briharley
would the 4.5's from the new bikes fit older models like pre 2003. like o lets say a 1996 sportster?
