1450 kit
Old 06-27-2008, 11:30 PM
WRAITH's Avatar
WRAITH
WRAITH is offline
Default 1450 kit
I'm thinking of upping my dispacement to 1450cc.Has any one done this,any problems?
Old 06-28-2008, 12:33 AM
david117585's Avatar
david117585
david117585 is offline
Default RE: 1450 kit
im also curious about this, anyone?
Old 06-28-2008, 02:12 AM
JosephGarcia's Avatar
JosephGarcia
JosephGarcia is offline
wow, i never heard of a kit that big. thats pretty sweet!
can the bottom end take it reliably without problems after x number of miles?
i would assume bearings wear faster with the added stress.
the case and evreything was designed to withstand a stage 1 1200cc upper end. the most common mod and most popular configuration.
Old 06-28-2008, 04:29 AM
128auto's Avatar
128auto
128auto is offline
He must be talking about NRHS 90 ci big bore kit, http://www.nrhsperformance.com/ekitsportster04.shtml
Is 1200 not enough? you always want more
Old 06-28-2008, 07:13 AM
Zimbob's Avatar
Zimbob
Zimbob is offline
The problems will be mostly with the build. get a good "wrench" that knows what he's doing then you should be ok.&nbsp\\;You may need some motor mount work but that will be minor.
Old 06-28-2008, 07:47 AM
drum412's Avatar
drum412
drum412 is offline
Cases will need to be bored out.....which means completely stripping the entire engine,&nbsp\\; not too bad if you know what your doing and have the right tools, but could be a nightmare otherwise. &nbsp\\; Beyond that, the most important part will be choosing the right combination of parts....for example, cams, ignition, carb work, the amount of head modification.&nbsp\\; I have a buddy that did the nhrs 90" kit, and it turned out real good, as a matter of fact he just did a 3000 mile road trip the other week, with no problems.&nbsp\\;
Old 06-28-2008, 08:55 AM
Fordster's Avatar
Fordster
Fordster is offline
I asked the guy that did my 1200 conversion for me because i was considering it also.He told me that it would be around 5000 dollars to do it so i decided 1200 was big enough for me.
Old 06-28-2008, 09:00 AM
traveler's Avatar
traveler
traveler is offline
Go read about this:
&nbsp\\;\\\\\\;
http://www.sportster.org/tech/quad88/
&nbsp\\;\\\\\\;
I know this wasn't your question, but you should be able to get the power you want out of a 1200 or 1250, IMHO.
&nbsp\\;\\\\\\;
If you do this, you might as well scrounge up the $$$$ and throw in a BAKER 6 speed while the whole motor is apart.
&nbsp\\;\\\\\\;
My 883 is 1200 converted, and a "74" sounds great to me!
&nbsp\\;\\\\\\;
~Joe
&nbsp\\;\\\\\\;
Old 06-28-2008, 10:21 AM
203Cree's Avatar
203Cree
203Cree is offline
ORIGINAL: traveler
Go read about this:
&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;
~Joe
That was a very entertaining read, thanks for posting!
Old 06-28-2008, 01:54 PM
99Sportster's Avatar
99Sportster
99Sportster is offline
ORIGINAL: traveler
Go read about this:
~Joe
&nbsp\\;
Wow, great stuff.&nbsp\\; Thanks for posting.&nbsp\\; I would be very interested in having that mod but need to find a wrench who I trust and also let me help so that I can learn.
Quick Reply: 1450 kit
