Removing Breather Bolts
07-09-2008, 04:10 PM
Have an 04 1200 Custom. I have been unsuccessful in removing the hollow breather bolts. Is a special tool required to remove them? [sm=confused06.gif]
07-09-2008, 04:26 PM
RE: Removing Breather Bolts
I'm not quite sure what you are referring to because the 'Rocker Cover' breather bolts simply unscrew with a socket or an open end/box end wrench.
07-09-2008, 04:37 PM
They are loc-tited in. lefty loosey, and probably a good amount of force
07-09-2008, 04:47 PM
Just be careful, I took mine out a couple of years ago due to leakage and the damn thing broke. Luckily a part of it was still sticking out so I could lock on with some pliers to finish the job. Just don't yank real hard, find a rubber mallet and giv'er a little tap a roo on the ratchet.
07-09-2008, 04:50 PM
Thanks. Seems the tool I am missing is strength.
07-09-2008, 06:46 PM
lol,,yep,,its an allen type bolt,,and if you're having a real tough time someone may have used red instead of blue thread lock.
if you get em off,,use blue when you reinstall,,blue is anti vibration thread lock,,red is semi perm.
RedLewy
02-15-2018 01:04 PM
Koffinkat
09-09-2013 03:47 AM
shore
02-03-2012 02:26 PM
fattboy1967
02-13-2011 06:11 PM
eq79
01-16-2011 02:36 PM
06 ,
backing ,
bolt ,
bolts ,
breather ,
custom ,
evo ,
harley ,
hollow ,
made ,
remove ,
removing ,
special ,
sportster ,
ss ,
threads ,
tool
