Charging Battery on a Nightster
A battery tender will not charge a completely dead battery. If you have, I believe, the Battery Tender Plus, then it will act as both a tender or as a charger. You'll need a charger. If your brother has a battery pigtail installed on the bike, then a Tender Plus may be enough to charge the bike to start, but only after sitting on charge probably overnight.
Huh? Of course a Battery Tender will charge a completely dead battery (assuming that the battery is not sulfated or otherwise damaged/defective). It will just take a very long time because you're only looking at a 750 to 800 milliamp charge rate. That means that it would take about 25 hours for a Battery Tender to charge a 20 amp-hour motorcycle battery while a 6 amp bench charger would only take 3.3 hours. Even a Battery Tender Plus will only manage a 1.25 amp charging rate so it would need 16 hours to recharge the battery in my example.
I'm no battery expert, and don't claim to be.........BUT, I've never seen it done, not even on a quad or lawn tractor battery that takes less cranking power...., but if you say so.
The following comes verbatim from the manual for my 800 milliamp waterproof model:
TIME REQUIRED TO CHARGE A BATTERY:
The WATERPROOF DELTRAN BATTERY TENDER® International Battery
Chargers charge at a rate of either 0.8 Amps (0.8 Amp-Hours per hour) or 1.25 Amps (1.25 Amp-Hours per hour). Therefore, a fully discharged 15 Amp-Hour battery will take approximately 15 hours or 9.6 hours respectively, to recharge to 80% capacity. Some large automotive or marine, deep cycle type batteries may take several days to fully recharge.
WORKING WITH A DEAD BATTERY OR A BATTERY WITH A VERY
LOW VOLTAGE:
If you try to charge a dead battery having a voltage below 3 Volts, the
WATERPROOF DELTRAN BATTERY TENDER® International Battery Chargers will not start to charge because an internal safety circuit prevents the battery chargers from generating any DC output voltage.
NOTE:
If a 12 Volt, Lead-Acid battery has an output voltage of less than 9 volts when it is at rest, when it is neither being charged nor supplying electrical current to an external load, there is a good chance that the battery is defective. As a frame of reference, a fully charged 12-Volt, Lead-Acid battery will have a reststate, no-load voltage of approximately 12.9 volts. A fully discharged 12-Volt, Lead-Acid battery will have a rest-state, no-load voltage of approximately 11.4 volts. That means that a voltage change of only 1.5 volts represents the full range of charge 0% to 100% on a 12-Volt, Lead-Acid battery. Depending on the manufacturer, and the age of the battery, the specific voltages will vary by a few tenths of a volt, but the 1.5-volt range will still be a good indicator of the battery charge %.
LOW VOLTAGE:
NOTE:
Furthermore, if you look up the manual for the Battery Tender Plus, you'll find that even those models will not charge batteries that drop below 3 volts.
I say again, if the battery is not damaged, even a little Battery Tender Jr or waterproof model will be able to fully charge it, you're just looking at it taking a few days. Most of us (myself included) are not willing to wait that long and would rather just throw the battery on the 10 amp bench charger for a couple hours instead, but if you don't have any other options, the maintainers can do it.
