Oil the filter, or not?
Old 04-11-2009, 05:30 PM
TestFlyer's Avatar
TestFlyer
TestFlyer is offline
Default Oil the filter, or not?
The HD wire mesh/paper air filter element that's on my 2005 883 says 'do not oil', but someone told me it's a HD contradiction. true?
The filter looked pretty dirty - fairly black with grime. I washed it, and it really doesn't look a whole lot cleaner.
Really thinking about simply replacing it - is this a wash it for lifetime filter or should it be changed (this has 15K miles on it).
Old 04-11-2009, 05:36 PM
anubisss's Avatar
anubisss
anubisss is offline
Replace it with a k and n. Then you can wash and oil it. The screaming eagle filter is not made to be washed and reoiled. .
RATROD HOG's Avatar
RATROD HOG
RATROD HOG is offline
15,000 i would give her a New one.
if it's a SE filter set-up make sure you get the correct one and Not the stock filter.
Old 04-11-2009, 05:45 PM
TestFlyer's Avatar
TestFlyer
The Part number on the back plate of the filter is 29044-048, and has the bar and shield elblem.
But, the K&N replacement for the 2004-2009 Sportster says it replaces OEM 29331-04.
I'm confused....
Old 04-11-2009, 06:01 PM
RATROD HOG's Avatar
RATROD HOG
the Part # 29331-04 is stock
that number you gave should be Part # 29044-04B that is a SE filter
Old 04-11-2009, 06:06 PM
TestFlyer's Avatar
TestFlyer
YEP, I JUST FIGURED THAT OUT - IT IS AN SE FILTER. So I guess I finished it off by washing it....sounds like it really needs a new one now.
Mail order?
Old 04-11-2009, 06:16 PM
RATROD HOG's Avatar
RATROD HOG
Dealer price 29.95 for SE filter
Ride Safe
Old 04-11-2009, 06:28 PM
TestFlyer's Avatar
TestFlyer
Ride Safe
Thanks a lot, RATROD.
Is K&N worth the extra dough (almost twice...)? notable difference in performance?
Old 04-11-2009, 10:13 PM
sweetroll's Avatar
sweetroll
sweetroll is offline
K&N is the way to go - they'll last as long as your bike does, so you'll probably save money later on. Plus air flow goes way up, and I would think the oiled filter protects better than dry. One thing to note - the filter should come oiled and ready to go, but in the future when you clean it, don't over-oil it - the oil will suck into the motor and may cause issues. I don't know if this is true on a bike, but my buddy's truck blew up after the oil screwed up the air sensor in the intake... just somethin to be aware of.
Old 04-11-2009, 10:27 PM
oct1949's Avatar
oct1949
oct1949 is offline
lets see, paper fitler, add water, holy smokes, it turns to crap.....imagine that...
Quick Reply: Oil the filter, or not?
