What's this bolt for and why is it leaking oil?
If the bolt was loose, the head is now cracked and leaking oil.
That bolt is threaded into a blind hole. the hole does not penitrate into the section of the head that floods with oil, therefore the head is cracked. The crack is due to bolt being loose and allowing upper motor mount to rattle. The constant shock of the rattle cause the head to crack.
Make Hd fix it.
Make Hd fix it.
well either your head has a minor crack allowing oil to get out through the back of the threading, or you simply have a leak from one of the rocker gaskets that just happens to be occuring just over that bolt. And yeah, it is a motor mount, it helps stabilize the cylinders.
Just curious, but why is the bike no longer under warranty?
I noticed that the bike is a 2008 Nightster, and the standard factory warranty is to 2 years, unlimited mileage...
Unless the bike was purchased before June 3, 2007 it still should be covered under warranty, unless I'm missing something.
