correct usage of motorcycle jack?
Old 12-31-2009, 07:44 PM
midnight2005's Avatar
midnight2005
midnight2005 is offline
Default correct usage of motorcycle jack?
So I got this Motorcycle jack for christmas and put it together and havent gotten to use it. Today I got my chance. It is from harbor freight and works great. I have included some pics and after you look at the pics my question is under the pics.
Should I have used straps to secure the gas tank?
By the way it worked great to drop the tank while it was full of gas although I did empty it before installing it.
Old 01-01-2010, 02:53 AM
malla1962's Avatar
malla1962
malla1962 is offline
Looks ok as is to me, what jack is it and whats it like with a bike on it.
Old 01-01-2010, 11:36 AM
midnight2005
It is from harbor freight. $79.00 and I havent gotten to try it on the bike yet. I needed to change the fuel pump with no help and a full tank. I know other jacks tend to let the tank fall but the pads on the motorcycle jack kept it straight and did great.
btw the question was meant to be a joke. I guess nobody got it.
Old 01-01-2010, 12:13 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
I did a similar thing with my jack from Sears. Used it to jack up each side of my daughter's Mazda Miata to rotate the tires.
Old 01-01-2010, 12:34 PM
midnight2005
I have often wondered if it would pick up a car.
Old 01-01-2010, 12:44 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
I have not doubt the bottle jack will lift a car. I doubt if the rest of the frame is really up to the job. Too much off that kind of lifting and I wouldn't be surprised to see it fail...bolts shear off, frame fold up, ect.
Old 01-01-2010, 01:47 PM
SportyPig's Avatar
SportyPig
Mine is rated for 1,500 lbs. picking up one side of a small car shouldn't be a problem.
Old 01-01-2010, 06:33 PM
gilmour68's Avatar
gilmour68
gilmour68 is offline
I've had the same lift for about a year now. Works good for the Sporty except the bike has to be put up on 1" boards for the lift to fit under. I slide it under from the exhaust side and have found a solid place to position the bike where tie downs aren't necessary, though I still use them.
Attached Thumbnails correct usage of motorcycle jack?-2004-sporty-lift.jpg   correct usage of motorcycle jack?-seiis-2-.jpg   correct usage of motorcycle jack?-seiis.jpg
Old 01-01-2010, 08:03 PM
SamStone's Avatar
SamStone
SamStone is offline
I used mine to drop the front frame and engine down to change the rack and pinion on a Windstar Van. I still put 4x4s in the jack when my bike is up just for piece of mind.
Old 01-02-2010, 01:53 AM
Topdogg's Avatar
Topdogg
Topdogg is offline
A Miata? I'm sure you could pick it up with one hand and still be able to remove the tires and rotate them with the other.
Quick Reply: correct usage of motorcycle jack?
