Rear brake pedal pad for sportster
I'd like to get one of these rear brake pedal pads but they don't list them for sportsters, anyone know if one of these will fit a sportster?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
or
or
I went in today and they only had the large in stock (way too big), I ordered a small and will make it fit one way or the other. The large had a stud but I don't know what the small will have.
I wanted this style because I already have the matching grips, I also bought the large pegs (rider) and the small pegs (passenger) and a gear shift peg in the diamond black, hope it all looks good together.
It may be advantageous to grind down/cut off the little meat tenderizer pleasure pimples that are on the top of your brake pedal before you drill a hole to mount the peg. The pedal is made of aluminum and is relatively soft material. The small versions (like the large one you looked at) have a stud that goes through. Use a file, old grind wheel (the aluminum will gum-up a grinder wheel) or just a hacksaw blade with tape on one end. A belt sander works really well. That's what I used for part of the action on this:
I am currently using the Kuryakyn clam shell ... thanks for the idea ... might do that in the future.
