Charging the Battery how do you guys do it.
Ok!This is my method,Nightster with alarm...Remove side cover,...turn ignition key to on,...remove Maxi fuse....remove positive terminal connections.Clip battery charger..negative to negative terminal mounting bolt on engine casing...attach positive to positive on battery... turn on charger... set amperage.
The reason I'm pulling the maxi fuse is it turns off the alarm,the reason I'm disconnecting the battery is I don't want to tempt fate and have any of the electronics connected while charging.
Quick charge 30min and I'm ready to go.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Options
Install one of these on your battery, and buy a battery tender that has a matching connector. When you need to charge it, plug it into the bike, and plug the charger into the wall. The security system has nothing to do with anything. My 09 has a security system with siren and that's the way to do it. Now in the warmer months, I just ride it. You are doing way too much work.
