Belt Tension
My manual says 5/16-1/4" so I set it at 2 notches on the debris defector which should be 1/4". I used the HD tool. My bike only has 1000 miles on it so it may have needed adjustment in the first place.
The factory recommended belt tension is way too tight. Take off the shocks, lift the rear wheel off the ground and the swing arm will be held up by belt tension alone, this is not good. With the shocks off and wheel up, loosen the adjusters equally until the swingarm just drops through its tightest point in the arc of travel. Then put your shocks on, tighten all the nuts and bolts and go ride. Doesn't matter what model, which year or if it is chain or belt this is the correct procedure if you don't wish to overstress your belt, bearings and output shaft. As a bonus you will unload your rear suspension a bit for some extra travel.
I know when I had my shocks off the swingarm dropped right down. It might have been loose as I was just coming up on the first service. I think I might loosen it a bit...it's still in Winter storage I haven't ridden yet. I can do the 1/4 turn twist tho...so maybe it's good.
Check your adjuster nuts once in a while also. I've noticed mine, and on others' bikes the rear axle tends to move a bit and become misaligned, as evidenced by a space left between one of the adjuster nuts and swingarm end. The design is a little lame as it allows for this to happen. I first saw this on my buddy's ironhead, which was dog tracking noticeably, then checked mine and had the same problem to a lesser degree. I've since seen it on other sportys. I also know of two people whose adjusters have actually broke, just more proof of poor design.
I'd be doing some close inspectin' ...that doesn't sound right. Check the axle nuts for proper torque, check the adjusters that they're not broken, lift the rear up and see if there is any bearing play in the axle. Check that the sprocket bolts are tight. The swing arm bolts. It would probably be a good idea to loosen the belt right off to check all those.
