Bike shuts off while riding!!!! WTF?
Old 02-10-2014, 01:30 PM
raq1025's Avatar
raq1025
raq1025 is offline
There are a lot of good suggestions already here, but I'll add my $.02.
I had a similar issue with the bike losing power, backfiring, and cutting out. I replaced / tightened EVERYTHING. Ultimately, it was a defective ignition switch. The switch would go momentarily off (even though the key was still in the run position.) I was finally able to isolate it because as soon as I felt the bike start to lose power & backfire, I reached for the key and turned it more towards run and the symptoms cleared for a short while. I replaced the switch and the bike has been trouble free since.
Old 02-10-2014, 04:42 PM
0EightN's Avatar
0EightN
0EightN is offline
Originally Posted by Hitechluddite
Next time it happens look at your speedo and see if it drops to 0 while your still moving. If so you've got a power problem if not it's most likely somewhere else, relay, ign module etc...
Mine drops to 0 while riding. What's this power problem you speak of?
Old 02-10-2014, 05:34 PM
wilburz's Avatar
wilburz
wilburz is offline
pull yer relays out and see if they have white stuff on them. if so replace.
Old 02-11-2014, 12:26 PM
mrfikser's Avatar
mrfikser
mrfikser is offline
I had a puppy once that would stop (and sit down) when I walked him...
turns out he was just tired and wanted to be carried, maybe your bike is the same way...
prolly not much help, but it got me another post closer to 2000...
Old 02-11-2014, 02:19 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,645 Likes on 1,135 Posts
sc413,
What year is this bike? Does it have circuit breakers, or fuses, or relays? Maybe it would help if we were all on the same page when it comes to describing electrical components from different years of bikes?
The older bikes just have circuit breakers. And a starter relay. Mine has four circuit breakers, and a starter relay that is maybe inside the headlight, my FSM is vaque on this.
Now they use fuses, and I guess some other types of relays too. And something called a maxi fuse, whatever that is.
John
Old 08-25-2016, 11:00 AM
Rudy Tanielian's Avatar
Rudy Tanielian
Rudy Tanielian is offline
Stage I
Default electra glide model 2000
Hi
My HD electraglide ultra classic model 2000 is cutting the electricity off while riding ...
No battery lose connection ...
Got a new circuit breaker and new relays ... And still the problem is the same
It begins to turn of after riding 5 min maybe when the engine gets hot
Any clue ???????
Old 08-25-2016, 09:33 PM
pjweber's Avatar
pjweber
pjweber is offline
Ditto, same problem here years ago on my 2006 1200C. I used to have all my keys and key fob dangling and blowing in the wind from the ignition and it just wore out the ignition switch contacts. Now I only put the key in the ignition and keep the rest of the junk in my pocket.
Old 10-02-2016, 05:20 PM
harley86's Avatar
harley86
harley86 is offline
1st Gear
the same thing happened three time with me , just got a 98 ultra classic it just died on the road going on 40 mile . couldn`t figure what is wrong , went in a parking lot and waited couple minutes and then start it again .. today i toke the bike out for a ride and the same thing happened again twice but the bike starts again .. not sure what is it now i will check on the ground wire and see but in the other hand if the ground wire or cable is loss the bike wont be able to start in the first place and the starter will just fast click trying to start. the bike starts from the first push on the start botton when the engine is cold but when it get hot it shot off i guess
Old 10-02-2016, 08:19 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
Old 10-03-2016, 01:23 AM
AaronG87's Avatar
AaronG87
AaronG87 is offline
I had a similar problem with my '08 xl1200n after doing some intake and exhaust changes. It wasn't a power issue, but rather a fueling issue; it had a tendency to suddenly idle rough and die while in low rpm's. was fixed with a power commander and dyno tune.
Quick Reply: Bike shuts off while riding!!!! WTF?
