Add a 12volt power source to your sportster / nightster
Old 03-19-2011, 02:10 PM
knightenforcer's Avatar
knightenforcer
knightenforcer is offline
Cool!
Believe it or not, I once turned an 06 Vrod into a full fairing/ batwing bagger with
HD radio, stereo speakers, etc...But, I'm not going to do that to my nightster. Going to keep it simple. I like the nightster's "old school meets technology" styling.
Although at times I do wish I have heated gear on...esp where I ride (near the ocean) most of the time...it gets really windy and cool.
Old 03-19-2011, 03:30 PM
2011Iron883's Avatar
2011Iron883
2011Iron883 is offline
Very cool. I was thinking about doing something along those lines so I could run my G-Tech meter to clock my 0-60 and 1/4mile et's...
Old 03-19-2011, 03:55 PM
editbrain's Avatar
editbrain
editbrain is offline
Nice. I did one of these the other day, but I didn't go to this extreme. Mine is real sloppy. I just took a 12V cig connector that I had, and soldered a SAE cable to it with a 15A fuse in it. Then used shrink wrap to seal it.
I keep it in my side bag that is bolted to the battery box where the battery band on my Dyna was located for charging phone, or a 12V air pump, computer usage, etc. I figured the 15A fuse that you cut off would work just as well.
I had all the parts laying around, and total cost was 30 minutes work.
That is a nice setup. Good job.
Old 03-19-2011, 06:32 PM
geneinnc's Avatar
geneinnc
geneinnc is offline
I was just thinking today about how nice this addition would be. I plan on using my Android X as a navigator, and I usually carry my Ham Radio Handie Talkie in my luggage.
No more hauling extra batteries and chargers now.
Thanks for the thorough instructions.
Old 03-21-2011, 06:17 PM
fiveliter's Avatar
fiveliter
fiveliter is offline
Originally Posted by Gpsjr10
Looks like you already had a connector hooked up for your tender, you could just plug your power outlet into that instead of adding another one from your fuse box. I use mine for the tender or I hook my power outlet into it and run the wire into my side bag with my phone charger to recharge it. It is already fused right off of the battery and you don't have to have the key on for it to have power.
I added my power outlet this way too. This was an easy way to power my GPS. I just dont leave anything plugged in when I put the bike away. I usually pull the outlet off and connect the battery tender.
Old 03-21-2011, 08:21 PM
editbrain's Avatar
editbrain
That is what I was getting at. Just use the one the SAE that I use for battery tender, but you have to admit. He did a fine job.
Old 03-22-2011, 08:09 AM
inswva's Avatar
inswva
inswva is offline
Very nice writeup, thanks.
Old 03-22-2011, 01:44 PM
SgtSkiddz's Avatar
SgtSkiddz
SgtSkiddz is offline
Was going to figure out how to do this this weekend. Now all I have to do is do it. Thanks for taking care of the "leg work"
Old 03-22-2011, 02:29 PM
bmrgold's Avatar
bmrgold
bmrgold is offline
I just use this... I already had a battery tender hooked up so I just plug it into that.
http://leclarepowersports.com/prodde...od=96533-00110
Old 07-31-2011, 02:45 AM
arod6's Avatar
arod6
arod6 is offline
After i did this mod, the neutral light was gone - any ideas? thanks.
Quick Reply: Add a 12volt power source to your sportster / nightster
