Priming the oil pump?
Old 06-06-2011, 07:37 PM
Emily's Avatar
Emily
Emily is offline
Stage I
Default Priming the oil pump?
hey I have a 79 ironhead and i just changed out my oil, I need to prime the pump but im getting a little confused with the GREAT clymer manual instructions...ha. So im suppose to unattach the sensor, unscrew the sensor element(i dont know what its actually called?) and let the oil drain out a little?
im all new to this so im just kinda wingin' it for everything ive done thus far..As far as priming the pump goes, if its not primed with that make the oil pressure light go all wacko on me? When the bike idles at lower speeds, or the rmps are just low in general(stop lights n stuff) the light will come on, and flicker. When im at normal riding speeds the light turns off.
Old 06-06-2011, 08:42 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
It is very possible that the oil pressure switch is bad or it was replaced with the wrong switch at some time. Best thing to do would be to remove the switch and put a pressure guage in it's place to check your oil pressure.
smellsbad2
Ironhead
03-02-2018 05:50 AM
Dgaroutte
EVO
34
06-29-2015 06:56 AM
tombeving
Exhaust System Topics
11-09-2009 11:23 AM
RoadkingFD
06-17-2007 12:36 AM
83ironhead
Oil Archive (no new posts)
10-05-2005 01:05 AM
Quick Reply: Priming the oil pump?
