oil pressure
Old Nov 9, 2009 | 09:59 AM
tombeving's Avatar
tombeving
Default oil pressure
Hey guys I need some help. I have an 05 Ultra Classic and on a trip to California the oil light came on and the oil pressure dropped to 0. We removed the dip stick and saw that oil was circulating so I rode it to the dealer. I asked the dealer to check my oil pressure and the tech told me the pressure was fine and the oil pressure switch was bad. Since there were fifeteen other guys waiting for me, I bought a new switch and figured I'd replace it when I got home. I drove another 1200 miles with no motor issues. I installed the new switch but I still have the same problem, oil light stays on and oil pressure reads 0. If I rev the motor to 2500 RPMs the oil light will go out and the needle on the oil pressure guage will move a little but as soon as it idles down the light comes on again and the pressure reads 0. Any ideas?
Old Nov 9, 2009 | 10:37 AM
beaureed445's Avatar
beaureed445
Another bad switch?
Old Nov 9, 2009 | 10:44 AM
tombeving's Avatar
tombeving
I thought about that, but I hate to buy another new switch just to find out.
Old Nov 9, 2009 | 11:13 AM
djl's Avatar
djl
Pull the new switch, attach an adapter and connect a guage that you know is good; you either have pressure or you don't. If you don't, pull the cam plate and check the pressure relief valve; it coud be sticking in the open position.
Are you still running the original cam tensioners? If so, have you checked them for wear lately?
Old Nov 9, 2009 | 11:20 AM
ultrat's Avatar
ultrat
switch w/ a known good one a friends evo sw/ ...
Old Nov 9, 2009 | 11:23 AM
tombeving's Avatar
tombeving
I checked the ohms on the new switch. The manual states that it should read 0 ohms from the pin closest to the clip to the crankcase. I'm not getting 0 so I believe the new switch is bad. To be on the safe side I'll rig up a gauge to check the oil pressure. Thanks.
ukbertie
EVO
19
Dec 3, 2025 08:24 AM
Dgaroutte
EVO
34
Jun 29, 2015 06:56 AM
BiggestDawg
Sep 27, 2012 08:00 AM
Emily
Jun 6, 2011 08:42 PM
83ironhead
Oil Archive (no new posts)
Oct 5, 2005 01:05 AM
