Today as I'm riding to work I notice that my oil pressure gage is all over the map. This now has me concerned as I found some oil in a spot that has never had oil on it and when I trace it I find that it comes from the rear jug up by the head on the right side. Why would my oil pressure go like this. I recently changed oil and filter when I had noticed the same thing so now I don't know what to think.
1st check the electrical connection on your Oil Pressure Sending Switch. It is located just behind the rear pushrod tubes and should have a rubber cover over the top of it. If the connection is good, and the wire is not chaffed up the line, then I would replace the sending switch itself. The oil pressure controls a contact inside of it which increases or decreases resistance based on the oil pressure itself. Kind of like a dimmer switch on a car. The resistance is then measured by the oil pressure guage and displayed as psi. If you are seeing oil on the right side of the rear cylinder then I would think that the crimped seal on the switch has gone bad and that 30 psi of oil pressure is spraying on your cylinder.
Roadkings PN 26561-84 MSRP $11.40
All other Touring with gauges PN 74406-87 MSRP $66.50
The reason for the difference in price is that the RK's just trigger a light when the pressure is low and the other one actually sends varying resistance signals to a gauge.
Good Luck.
Your oil pressure may swing, but it won't jump around erratically. When you say "all over the place", it sounds like an electical problem (like the switch or sensor) than an oil problem.
If you've got good electrical connections and sensors, I wouldn't disregard what the gauge is telling you. Engine might be getting ready to **** the bed.
Good Luck.
I will check that. Of course mine is the more expensive one why should I get off easy?
Per the electrical service manual on my Ultra. Without starting bike turn the ignition to ON, gauge should come up to Zero. Next turn off, unplug connector off of sending unit. ground the Grn/Yel wire using a jumper to ground. Turn on ignition, gauge should read 80 psi. If it doesn't then connection at gauge or the harness connector is probably bad or loose, since you say it is jumping around. Also you could use an Ohmmeter and due a continuity test on that Grn/Yel wire from connector at the back of gauge to the sending unit connector.
Ihave an 08 and last year on the way to Yellowstone oil pressure started fluctuating all over. Scared the hell out of me. Hd replaced the sending unit and later in the trip the guage. I finally found the engine groung strap behind the starter loose. Tighten and been fine every since.
At 106k that is what I am worried about!
Originally Posted by ONEDOWNAND5UP
You don't mention the miles on your bike, but anything near 20,000 mi. bears a cam chain tension-er check, and hope like hell that isn't your issue.
Mark
I did mention the mileage a couple posts up but as it turns out it was loose connections. Being that mine is a 98 my gauge only goes up to 40 PSI so the check mentioned above is not good for my ride. I uncovered the the sensor and the screws were loose so I re-tightend and also had to clean the contacts for my head lamp and all is good now
Just curious - a lot of folks are suggesting cam tensioners as being a possibility for fluctuating oil pressures. I know that this is a problem with the 88's, but mine is a 96. Is this a problem with the 96's also? I've got pressures normally at 32, but at certain rpms, it drops to about 18. Then back up to 32 again.
