Oil pressure has gone crazy
Old Sep 26, 2012 | 09:03 PM
jeg607's Avatar
jeg607
Forgot to mention - 24500 miles on it.
Old Sep 26, 2012 | 09:18 PM
piasspj's Avatar
piasspj
Originally Posted by jeg607
Just curious - a lot of folks are suggesting cam tensioners as being a possibility for fluctuating oil pressures. I know that this is a problem with the 88's, but mine is a 96. Is this a problem with the 96's also? I've got pressures normally at 32, but at certain rpms, it drops to about 18. Then back up to 32 again.
Sounds like it could be normal. At idle my gauge shows almost 0 PSI, has since the bike was new.
Old Sep 26, 2012 | 09:24 PM
Bill03E's Avatar
Bill03E
if you have an 03 like in your sig , you don't have a 96" motor you have a 95" and the tensioners must be checked.
Old Sep 27, 2012 | 07:34 AM
jeg607's Avatar
jeg607
Thanks, Bill03E, for that info. Both I and the original owner thought it was a 1584 cc Screamin' Eagle. At least that is what the factory production sheets show for this bike. Was supposed to have been sent to the Screamin' Eagle department to have the 1584 cc engine package put in, bike was ordered as a 1584, and sold to me as a 1584 cc. The mystery deepens...
I'll have to get in touch with the dealer for more investigation!! Makes a big difference if it is a 95, because it has the same cam tensioners, as you pointed out.
I'll post what I find out about this engine later!
Old Sep 27, 2012 | 07:49 AM
fwb35's Avatar
fwb35
Up to 06 had the crappy tensioners and they have to be checked, they last about 20k to 30k miles, if they come apart they can take your engine out. When changing your oil cut your filter open, if you see any orange bits of plastic you have a problem, the plastic can clog small oil passages and also ruin your oil pump causing engine failure. I put a oil pump spring kit in my 1999 EG 88 tc for better oil pressure, it helps to get more oil to the top of the engine and reduced my engine noise when hot quite a bit.
Old Sep 27, 2012 | 08:00 AM
jeg607's Avatar
jeg607
Thanks for the feedback, folks! As always, the forum is a wealth of info! I'll be checking the tensioners right away.
FL-kruzen
Mar 27, 2013 09:04 AM
scaley
Oil Archive (no new posts)
Sep 20, 2012 04:55 AM
Harbri
Shovelhead
Nov 13, 2011 09:34 PM
db45
Feb 4, 2010 06:33 PM
83ironhead
Oct 5, 2005 01:05 AM
