No oil pressure
Old Nov 13, 2011 | 04:19 PM
Harbri's Avatar
Harbri
Default No oil pressure
After my complete overhaul, the oil lite comes on,i took off the pressure sensor to prime it,comes out good steady flow.i am running 25/50 oil. any ideas? thanks Harbri.
Old Nov 13, 2011 | 04:58 PM
Uncle Larry's Avatar
Uncle Larry
First thing I'd do is put an oil pressure gauge on it to check pressure. You could have a bad/worn sending unit for the oil pressure light.
Old Nov 13, 2011 | 05:04 PM
sqdealgeorge's Avatar
sqdealgeorge
Default oil pressure sensor
It only takes 3psig to knock out that light I would run 50 wt oil and make sure that the oil is returning to the tank If it is ride on
Old Nov 13, 2011 | 09:34 PM
Harbri's Avatar
Harbri
Could it be air in the system ,after all it was totaly drained,only ran it for 3 4 minites.
scaley
Oil Archive (no new posts)
Sep 20, 2012 04:55 AM
purple99sporty
May 7, 2012 06:48 PM
poppop
Shovelhead
May 23, 2009 03:18 PM
tgarrett1
Jul 9, 2007 09:05 AM
